Design SuiteThe Visibility tool
Tool
Tool set
Shortcut
Visibility
Basic
V
The Visibility tool changes the visibility of the layer or class associated with a clicked object, or only the visibility of the object itself, depending on the mode. If you click an object in a sheet layer or design layer viewport, only the visibility in that viewport changes (with some exceptions); for viewports with the visibility set by style, layer and class visibilities can only be edited from the Edit Viewport Style dialog box (see Creating and editing viewport styles). A viewport's object, class, and/or layer visibilities can be changed when editing the viewport's design layer; see Changing viewport visibility from the design layer. You can also make rapid changes to the visibilities of multiple layers, classes, or objects in the drawing by double-clicking the tool itself.
Several modes are available to specify whether to change class, layer, or object visibility, and to set the type of visibility change to make.
Mode
Description
Classes
Affects the visibility of the clicked object's class
Layers
Affects the visibility of the clicked object's layer
Objects
Visible
In Classes or Layers mode, sets the class or layer of the clicked object to be visible; in Objects mode, makes the clicked object visible
Invisible / Hidden
In Classes or Layers mode, Invisible mode sets the class or layer of the clicked object to be invisible.
In Objects mode, Hidden mode shows the clicked object "ghosted" (transparent with a light blue tint). In the Vectorworks preferences and Quick Preferences menu, you can change hidden objects to be invisible, if desired.
Greyed
In Classes or Layers mode, sets the clicked object's class or layer to gray
Preferences
Specifies the behavior when the Visibility tool is double-clicked
There are several other ways to change class, layer, and object visibility in the drawing area, in addition to the Visibility tool.
Class and layer visibility: See Setting global visibility with class and design layer options for details about the Class Options and Layer Options settings.
Object visibility: See Object visibility commands for details about commands on the View menu.
Layer or class visibility changes using the Visibility tool
Object visibility changes using the Visibility tool
Visibility tool shortcuts
Visibility tool behavior in embedded viewports
